铁甲网首页 铁甲论坛 玉柴的无尾机
玉柴的无尾机
铁甲人 2009-09-12
3746 19
Introduce:
Specifications
Item Unit YC55SR Excavator
Machine weight  kg 5830
Volume of backhoe  m3 0.2
Outer width of bucket mm 741
Dimensions
Maximum length if transportation mm 5715
Overall width mm 2000
Machine height mm 2660
Width of track mm 400
Length of track mm 2608
Undercarriage to ground mm 345
Between platform and ground mm 723
Platform tail turning radius mm 1000
Sprocket to idler centres mm 2060
Engine
Model   Yanmar
Power kw/rpm 36.9/2200
Technical Specifications
Operation hydraulic pressure Mpa 24.5
Maximum flow L/min 110+11
Maximum digging force KN 37.4
Gradeability ' 30
Pressure to the ground  Kpa 31.6
Walking speed km/h 2.8/4.7
Maximum hauling force KN 44
Swing speed of platform rpm 10.4
Range of operation
Maximum digging height mm 5938
Maximum digging depth mm 3789
Maximum platform tail turning radius mm 2467
Maximum digging radius mm 6373
Maximum depth for bulldozing mm 6227
Maximum dumping height mm 4051
